Maya 2018
Maya 2018
Maya 2018
Hi one of my student got new HP laptop and tried to install maya 14 and 18 version both but all four views which we see normally getting white screen all
over in all view need help to fix the issue can any one faced the same issue please help me to solve the issue.
Thank you
tony.su
Autodesk Support
Autodesk Support
I guess it's graphics card or graphics card driver issue.
Could you try to change VP2.0 setting? In preferences, set vp2.0 to other mode.
Tony Su
Product Support
sean.heasley
Hi @Anonymous and welcome to the community!
What kind of GPU is in the laptop?
Are the drivers up to date?
Generally with this type of issue its due to a GPU error and/or the viewport like @tony.su said.
Let me know if anything changes!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion @tony.su provided work for you? If not please come back with more information so we can further assist you!
If your issue is solved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
