Announcements
Maya 2018 Viewport issue with Frame selection
Message 1 of 9
Hi i'm having the same problem. i already delete the preferences even reinstall the software. However it keeps disappearing everything in all my scenes.
Any suggestion?
thank you
Replies (8)
Message 2 of 9
Hi
For me i just rename prefs folder to prefsOld and let maya to it's default preferences that's it
Message 3 of 9
sean.heasley
Hi @Anonymous
Does this happen on a scene you've been working on or does it occur on fresh empty scenes as well?
Also, while @Anonymous posted a video in their thread, could you please post a video of your issue occurring as well so I can see if there is anything different or any signs that might clue me in to what the solution could be?
If you need a video capturing program, Screencast is a great option that we use here at Autodesk
Let me know if anything changes!
Message 4 of 9
Dear @sean.heasley,
It happened even with the new scenes too. However, i followed the suggest of @Anonymous  and now Maya runs well.
Thank you.
Message 5 of 9
sean.heasley
Ah great! I'm glad it worked for you!
Just to mark this thread as solved, deleting your settings/preferences like @Anonymous did in this thread is what resolved your issue correct?
Let me know if those steps solved your solution or if you solved it in a different way!
Message 6 of 9
Yes,
It was.
Thank you again!
Message 7 of 9
Maybe it's the same problem.
Once I use Frame Selection or Frame All ("F" / "A") my perspective camera goes to a NaN in translate. When select the camera, I reset the transformations and put it in Default view "Alt+Home" it returns and I can use my viewport again, but every time I press "F" or "A" it happens again. I don't want to reset my sett/pref.  Is there anything else I can do? I'm using Maya 2018.
Thanks.
Message 8 of 9
mspeer
Hi!
Check settings for Camera -> View Fit -> Fit factor
in preferences, (set value  "0.95").
Message 9 of 9
Thank you! That has solved my problem.
