Announcements
Cube polygons smooth by default?
Hello everyone, I am currently working on a low poly model that makes use of the low poly aesthetic. In order for it to work, I need the lighting to be nice and sharp on every polygon. I've noticed, however, that by default the cube polygons are "smooth". I don't mean smooth as in pressing 3 / smooth mesh, I mean smooth as in even though there are only a small amount of polys, the shading makes it look as if the surface isn't rough. If I duplicate the faces, then delete the original ones, the duplicate ones have the smoothness/shading I am looking for. Here's an example of what I mean:
All I did was create a cube (8, 8, 8, 2, 2, 2), and move the edges around a bit. Here's an example of what I mean by smooth, and what I do not want:
x8bjxN0
Then I selected all the faces -> shift right-click -> duplicate faces, disabled keep faces together, deleted all the original faces:
Nf6sDwH
and now you can see the shading is much rougher and pronounced. What is causing this and how do I fix this? I am using Maya 2016 Extension 2.
Thank you for any help!
RFlannery1
You can get the look you want by using hard edges.  To do this:
  1. Select any or all of the edges.
  2. Under the "Mesh Display" menu, select "Harden Edge".
I don't know how to make it do hard edges by default, though.
That works, thank you! If anyone knows how to make it the default, then let me know as well please 🙂
mspeer
Hi!
For modeling and preview purpose (in Viewport only) you can use in Viewport menu:
Shading -> Flat Shade All
