Hi @Anonymous
Does this happen on a scene you've been working on or does it occur on fresh empty scenes as well?
Also, while @Anonymous posted a video in their thread, could you please post a video of your issue occurring as well so I can see if there is anything different or any signs that might clue me in to what the solution could be?
If you need a video capturing program, Screencast is a great option that we use here at Autodesk
Let me know if anything changes!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Ah great! I'm glad it worked for you!
Just to mark this thread as solved, deleting your settings/preferences like @Anonymous did in this thread is what resolved your issue correct?
Let me know if those steps solved your solution or if you solved it in a different way!
All the best,
Sean Heasley
Maybe it's the same problem.
Once I use Frame Selection or Frame All ("F" / "A") my perspective camera goes to a NaN in translate. When select the camera, I reset the transformations and put it in Default view "Alt+Home" it returns and I can use my viewport again, but every time I press "F" or "A" it happens again. I don't want to reset my sett/pref. Is there anything else I can do? I'm using Maya 2018.
Thanks.
