Hi, in my maya 2018 i can see 3 differents layouts, Persp - 4 views - Front+Persp and i want to add more like Uv's or Hypershade, but i cant find where i can do that i try to select another layout and i only have 3 different layouts.
Hi @Anonymous your title 'Panel Layout Interface' was edited for clarity by @sean.heasley
Solved by sean.heasley. Go to Solution.
Hi!
Read this:
https://forums.autodesk.com/t5/maya-forum/quick-layout-menu/td-p/7436512
But i also recommend to use Workspaces for layouts:
Please read the Maya Online Help / Documentation for more details.
Hi @Anonymous
The thread @mspeer linked is a solid resource and I'd also like to backup what he is saying on custom workspaces. These are a great way to set up Maya exactly how you like it with whatever windows/tools you consistently use!
You can find more information on workspaces and customizing them here!
Please let me know if this helps you out or if you need any more information!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in to see if you need more help the Panel Layouts. Did the steps that @mspeer and I provided on using custom workspaces help resolve your issue?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Sorry but i cant solve my problem with creating a new layout, i want to add Persp/Uv Editor to my quick acces from the left of the program but when i create a new layout, no add anythin there, only i create a new layout but i cant get a quick access.
Hi @Anonymous
Once you have created the new layout you need to change one of the three on the side. If you right click one of them, you should see the new layout you made appear at the bottom and then you can set it to be that layout.
Please let me know if this information is helpful or if you need any more assistance!
All the best,
Sean Heasley
Hi @Anonymous
Unfortunately I don't believe you can. I haven't tweaked the layouts interface much in the past but when I was testing for this I was trying to see if it was possible to add a 4th layout but I don't believe its possible.
I'm gonna double check with one of our dev team members to make sure there wasn't a step we missed and I'll let you know!
All the best,
Sean Heasley
