- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I noticed inconsistent behaviour with border vertices using the target weld tool (TWT).
To be more specific.
When using the TWT, vertices get highlighted when you hover over it, indicating you can weld that vertex to another.
Yet most of the time border vertices wont get highlighted, so merging these vertices is not working, as they wont be selected / affected by the TWT. Also, in these cases, it wont let you snap a non-border vertex to the border vertex or vise versa.
There are times though, when i'm able to merge border vertices just fine using the TWT. These cases are rare though.
Why does it work at times, and then again it doens't?
What criteria needs to be met in order for it to work / not work?
Or ist that a bug or a feature i dont unterstand?
