Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
[Maya 2017] Error - drInit.mel line 1961: Object '' not found. // ?
Message 1 of 24
Does anyone know why this error message is continuously popping up in Maya 2017? Everything was working perfectly fine, then it crashed, and now this message is appears as soon as I open up Maya. It is also appearing after every action I do (click on a mesh, that message appears, click on a mesh again, it appears. I'm not sure how to fix this..
Thank you.
Replies (23)
Message 2 of 24
have this problem too
Message 3 of 24
same problem here. it just crashed, next time i open Maya, it keeps getting me the '../drInit.me line 1961: Object '' not found' error.
any ideas? 🙂
Message 4 of 24
Message 5 of 24
Hi guys
It looks like this is some kind of issue related to the modeling toolkit plugin. I haven't been able to narrow down the exact cause, but I did manage to reproduce it on my PC.
The way I fixed it was very simple. Just go to
Windows > Modeling Editors > Modeling Toolkit
And it seemed to correct itself
Failing that you can do the following:
1) Close Maya
2) Browse to your prefs folder
3) Delete or rename the pluginPrefs.mel file
4) Restart Maya
Hopefully one of those solutions will work for you.
Cheers
Mike
Message 6 of 24
MrMeireles
Worked for me. I just have to click and voilá.
Thanks.
Remember to share your knowledge. That's good for everyone!
MrMeireles
[Maya 2022.5/2025]
[Windows 10 Pro 64 bit Intel i9 9900K 64GB]
[MSI Suprim RTX 4080]
Message 7 of 24
Thank you! Worked for me too!
Message 8 of 24
margaretsidero
Community Visitor
Community Visitor
That did the trick... Thank you!
Message 9 of 24
natalietai_m
hey erm what is the preferred folder you mentioned? and where can i find it? I'm still having this error problem after went into the modeling toolkit.
Message 10 of 24
Hi natalietai.m
Sorry, I meant "preferences" folder. You can find the official instructions in the documentation:
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Maya/fil...
Mike
Message 11 of 24
MrMeireles
That error was corrected in the latest service packs. I suggest you install
them.
MrMeireles
[Maya 2022.5/2025]
Message 12 of 24
natalietai_m
Where can I get these service packs? Whats a reliable website to go to ?
Message 13 of 24
MrMeireles
Autodesk.com
MrMeireles
[Maya 2022.5/2025]
Message 14 of 24
thanks
Message 15 of 24
Just no note that it could also be a clashing folder. I also had this problem and realized I had a folder called 2015 x64 in teh Maya tab. So if you download a newer version of Maya, make sure to completely remove your previous versions. I only realized when trying to fix this issue haha!
Message 16 of 24
Hey, I think one of the causes is deleting the modelling toolkit where you have the attribute editor and channel box. I deleted it yesterday cause it was bugging me then I started having this issue. Thanks for the solve!!
Message 17 of 24
Thank you so much.... this error was very annoying but everything's working all fine with your modelling toolkit tip !!!
Message 18 of 24
Thank you!  It fixed the problem like magic!
Message 19 of 24
babu.rahaman
Thats really great....its work like magic ..thanks a lot
Message 20 of 24
I got this error today! Just copied the error message, then putted on google and find this solutions work perfectly.
Thanks buddy.
Easy and best!
Thank you.
Thank you.
