I have been using MASH in Maya 2018 on Mac making simple dominos, similar to a tutorial found Here: https://www.youtube.com/watch?v=fD6boXzwRxY . I have the curve with dominos falling well but I make my grid of dominos, apply Random and Transform nodes running 100, 1, 100 dominos with 150, 0, 150 Distance. At this point, when I hit play, the curve of dominos runs dynamically no problem. As soon as I apply Dynamic node to the grid, it says // Error: No Mesh on Instancer/Repro // and none of the dynamics work on either the grid or the curve dominos. I have searched everywhere for a solution and have found nothing. Please help.
Thanks!
Ben---
Solved by waverider5023. Go to Solution.
Hi @TheMouseman1212 and welcome to the community!
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
I'm just checking in again to see if you need more help with this. Are you still having trouble with this issue?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
There seems to be a nasty bug in Mash that has to do with the BulletSolver. Sometimes when you delete a Mash network that had dynamics, you are not able to delete the MASH_BulletSolver from the Outliner. If you create a new Mash network, apparently it tries to use the old BulletSolver and that is where the error crops up.
I don't know a way out of it. How do you remove items in the Outliner that can't be deleted normally?
I can approve what you say. Same scenario happend to me (I deleted a MASH network which was using Mash_BulletSolver), and this error appeared. It is impossible to delet BulletSolver node, I also tried to unlock node, but nothing happend..It is quite annoying.
You are correct. I was having the same issue. I deleted a MASH network with dynamics, which led to the Error. And it has to do with the original Bullet Solver. To fix this, I deleted the dynamics for each MASH network (thankfully I didn't have any major customizations ). Then I deleted the Bullet Solver in the Outliner. And then I made new dynamics for each MASH network. Everything seems to be working fine now. This is a fix if you don't have any major customizations to Dynamics in multiple MASH networks. Hope this helps
