Issue in exporting camera from Maya to After Effects
AlaaAliTaha
Message 1 of 8
AlaaAliTaha
Good day, guys could anyone please help me exporting maya camera with it's tracking locators to use it in adobe after effects,
I've used several methods, but non of them seems to be working as the exported locators and camera's y and z axis values have been always inverted after being imported into after effects as shown in the attached images,
I used three methods, I've tried to import the whole .ma scene, I've also used after effects live link plugin, and used maya to ea script
with no success.
Thanks in advance.
Replies (7)
Message 2 of 8
sean.heasley
Message 3 of 8
sean.heasley
Hi @AlaaAliTaha
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 8
AlaaAliTaha
@sean.heasley didn't work 😞
and thank you for your help
Message 5 of 8
sean.heasley
Hi @AlaaAliTaha
Did anything different happen or did you get the same result?
Also, can you try making a new blank scene in Maya with a camera and exporting to see if the same issue occurs?
Message 6 of 8
sean.heasley
Hi @AlaaAliTaha
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 7 of 8
Im having the same problem.
Message 8 of 8
jerry
I had the same issue using VRay an Maya2019.
Make sure your camera - Attributes - Film Back - Fit Resolution Gate - is set to fill and not to Overscan!
