Importing dwg and dxf in 2018
Message 1 of 27
I've reviewed all the posts I could find on this topic and still have not seen anything that resolves my issue. I think, I hope, I'm missing something simple. I've tried to import dwg and dxf files into Maya 2018 by using import and also open scene. I am getting the unrecognized file type response. I checked and ATF plugin is loaded. I'm not sure if there is a way to export to an ATF compatible file from Autocad. I've attempted to find a command for this but did not find a solution. I'm using Autocad 17 for Mac. Please let me know what things I can check or if I'm missing something about how to use ATF.
Replies (26)
Message 2 of 27
sean.heasley
Hi @Anonymous and welcome to the community!
When you get a chance, can you please check to see if you have the DirectConnect.mll plugin loaded?
If you do have it loaded and that doesn't solve the issue, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Let me know if anything changes!
Message 3 of 27
Hi Sean,
Thank you for the reply. I don't see DirectConnect.mll in the plugin manager at all. My understanding was that ATF replaces that plugin?
Thanks again
Message 4 of 27
sean.heasley
Hi @Anonymous
Right my mistake the ATF plugin should work.
When you get a chance, can you please zip and attach the dwg files here or via dropbox/google drive or another file sharing program so I can take a look at it?
Message 5 of 27
sean.heasley
Hi @Anonymous
Thanks for sending me the file!
I did some testing and it looks like importing DWG files works fine on Windows but there's a bug where it isn't working on Mac at the moment.
This has been logged with our dev team and they are working on a fix.
Please let me know if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 6 of 27
Thanks for the update. Do you have a timeline in mind for the fix?
Message 7 of 27
sean.heasley
Hi @Anonymous
At the moment I can't say when this will be fixed but I'll be sure to update this post when the fix has been implemented!
Message 8 of 27
Any update here?
Message 9 of 27
sean.heasley
Hi @Anonymous
Not yet but I'll update here as soon as I have more information!
Message 10 of 27
Hi I'm wondering if theres been a fix for this over the past few months? I've been having this problem as well.
Maybe you can help me by converting the file for me?
Message 11 of 27
mspeer
Hi!
@Anonymous
This file imports fine in Maya 2018.2 on windows.
Message 12 of 27
jill.ramsay
I think the problem is Mac-specific. I apologize this is still not fixed. In the meantime, here's a workaround: convert your file to SVG - I used this free online utility: http://www.dxfconverter.org/ - and then import it. I've converted your file here.
Message 13 of 27
Yes it's not working on my Mac. Thank you for converting!
Message 14 of 27
Hi I have converted my files from .dwg to .svg but it still says files unrecognised when I try to import them, I am using a Mac and Maya 2018 any help is greatly appreciated
Message 15 of 27
arqjpardo
Hi Jill, I had converted my .dxf file to .svg file, but I have unit troubles after import it to Maya, How can I fixed? Thanks, best regards!
Message 16 of 27
jill.ramsay
What exactly are the unit troubles? If it is just the wrong size, apply a uniform scaling factor to it and then freeze the transforms.
Jill
Message 17 of 27
sopedro01
In Mac the way i found to do this was, Import dwg into illustrator and then save as Illustrator file.
Then in Maya go to create -> Adobe Illustrator Object , choose the .ai file and select Import as Curves ( Bevel Fails).
NOTE: Maya just accept Illustrator 8 so, save the file in that version.
Hope this helps someone,
Pedro
Message 18 of 27
arqjpardo
Hi Pedro, I just tried your advice and it works!, Thank you, best regards!
Pedro
Message 19 of 27
Hello
I'm having the same inconvenient trying to export from AutoCAD 2013 to MAYA 2018 on a Mac. I already tried converting both .dwg and .dxf to .svg but MAYA reads ‘unrecognized file‘
Is there, by any chance, any update to fix the bug already or another solution to import CAD files?
Thank You!
Message 20 of 27
I also have same problem. I checked the plugins and they are all intact. The import is always successful, only that the drawing use to be very small and the scale tool does not work on it. sometime I will see the imported file in the outliner only and not in the view ports. Attached is the error message that always comes in before the file appears on the outliner
