Imported .DWG not showing right
foxsuno
Message 1 of 8
foxsuno
 Hello!
 My curves from Civil3D is not showing right on maya, I tried to see if there's some thing that I do not adjusted right, but I could not find.
Thanks.
https://i.imgur.com/pUqdq3E.png
Replies (7)
Message 2 of 8
sean.heasley
Hi @foxsuno
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it? If the file is confidential or under NDA please send it to me in a private message instead of posting it here.
Message 3 of 8
sean.heasley
Hi @foxsuno
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 8
sean.heasley
Hi @foxsuno
Thanks for sending me the files!
They look the exact same on my end so you may want to double check how they look in Civil.
Can you post a screenshot of them in Civil here?
Message 5 of 8
foxsuno
https://i.imgur.com/Z8CatOs.png
Message 6 of 8
sean.heasley
Hi @foxsuno
Is it being exported on the origin and/or as one object?
I don't know a lot about Civil so I'm not sure what the ideal pipeline is for going from Civil to Maya.
Message 7 of 8
foxsuno
I really don't know too, i'm selecting the curves that I want to export and exporting as a .dwg, bur for some reason, some of them just don't stay the way it should be, I don't know if I should check some options before exporting them
