I've tried to figure out how for about a little over a year and I don't know how to do it. I know how to do it with paint fx to some degree, but not with x-gen at all. Now if I make hair I know I can make the hair collide with the mesh the hair's attached to, but not other objects. (Another thing that's related to my question is that I don't know how to make xgen grass react to wind either. Can you make the x-gen grass collide with objects, and also have it moving in some wind?)
Solved by sean.heasley. Go to Solution.
There is a collision modifier. Make an alembic cache of the object/s you want to collide against and add the collision modifier and point the to cached geo. For wind effetcs from a Maya field, you'll need to use an animwire or control wire modifier. With an animwire modifier, you can create a dynamic nHair system and that can be affected by fields and collisions but as only the guides will collide, you'll still need a collision modifier to have the primitives collide with the geo.
This is covered in the documentation:
Cheers
Hi @Anonymous
To add on to this, here's a video that shows a simply wind modifier with a feather created via Xgen. The same workflow can be applied to grass.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Thank you so much for informing me on this. I've tried getting help about this before from my teacher, but I feel like she focused more on the fundamentals than stuff like this. It's greatly appreciated.
