How to Get Custom Plug-in working?
sweetpea09234
sweetpea09234
So I found this plug-in that would allow me to import PMX files and Followed its instructions, to what I thought was correct, since I've done this before.
This is the Github link:
Could it be these Files are more strictly meant for older versions of Maya or are I doing something incorrectly?
The last one is from maya 2017
If I go to like 2016 could that help?
Replies (23)
sean.heasley
Hi @sweetpea09234
There wasn't a github link in your original post, can you post it again?
Usually with custom scripts there's a line of Mel that needs to be run to activate the plugin, have you tried this?
sean.heasley
Hi @sweetpea09234
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
sweetpea09234
https://github.com/gameboy12615/MMD4Maya
Sorry Didnt see the reply, but no im still struggling with it.
sean.heasley
Hi @sweetpea09234
Thanks for posting the link!
I had no trouble with it with 2016 so you may indeed want to rollback to and older version of Maya in order to use this plugin.
sweetpea09234
Ok so there is the new problem, I need this plug in to work for 2017 or newer.
I cant download 2016 because Im on the educational version since it only rolls back 3 years (2019,2018,2017)
michaelkdaw
It seems there is a second branch of the code that is for maya 2017:
https://github.com/gameboy12615/MMD4Maya/tree/maya2017
Have you tried that?
From the README.md file:
master branch: maya2015~maya2016
maya2017 branch: maya2017
sweetpea09234
Hey @sean.heasley sean.heasley
where you actually able to get a file in? like an actually pmx file to be recognized by maya 2016?
I import the ones im trying to get in here and it keeps saying unrecognized file type.
sean.heasley
Hi @sweetpea09234
Yes I was able to import a file fine.
Did you have a chance to try @michaelkdaw's suggestion?
sweetpea09234
@sean.heasley
Do you by any chance have a video of how your uploading (Importing) it?
I have a feeling im doing it wrong even though Im following the instructions?
and I uninstalled 2017 do download 2016, so i didnt get a chance to try but this way is so close for me
sean.heasley
Hi @sweetpea09234
I just did it the exact way the steps are laid out in the screenshot on the github link.
sweetpea09234
Hey @sean.heasley
Ok ok, I got a video of me to try to import it. I do not a "terms of use" pop up. So I think I'm obviously doing something wrong. I've never used plugins like this so I think my stupidity is getting the best of me.
This image I'm trying to follow but it doesn't even pop up.
Also, I'm not importing a VMD file, I  just want the model :_:
Thank you for trying to help me with this tedious task.
Also this is one of the PMX files im trying
sean.heasley
Hi @sweetpea09234
Hmm that's odd.
When you get a chance, can you please zip and attach the pmx file here or via dropbox/google drive or another file sharing program so I can take a look at it? If the file is confidential or under NDA please send it to me in a private message instead of posting it here.
sweetpea09234
Hey @sean.heasley
sure thing I've tried with both of these files.
sean.heasley
Hi @sweetpea09234
Thanks for sending me the file!
Here's a quick video of my setup and getting the tool to function.
Screencast will be displayed here after you click Post.
1c9a8ea4-6eea-4883-bd6b-aa75f11e0ba5
sean.heasley
sean.heasley
Hi @sweetpea09234
sweetpea09234
You win! Thank you! I accept a victorious defeat and everything is now working.
Ok, so I'm basically trying to do the exact same thing...
Ive watched y'alls videos but they don't show how you download the plugin in the first place. obviously I don't see any neon green download button on the GitHub page so I assume I'm supposed to copy and paste lines of code?? or is there a folder somewhere?? lol its kind of ironic I'm working with a sour Luka too. So, um if you could help me figure out what to download/copy/paste that would be great
Really sorry for bothering you I'm a bit of a newb with Maya
Thx!
michaelkdaw
I haven't downloaded or tried it, but from what I'm reading from the past posts, make sure you're on the "maya2017" branch, then click the green "Code" button, and choose "Download ZIP". The contents of the zip file should match the files in the repository. From there, you should be able to follow the instructions on the github page to install the script.
