How to contact Autodesk Technical Support?
hagen.deloss
Alumni Alumni
Message 1 of 13
hagen.deloss
Hi forums folks 😄
Posting this on behalf of my colleague @sarah.deflaminis from the Autodesk support team.
There are a few modalities that Autodesk offers for getting in touch with Technical Support outside of the Autodesk Forums. Please use our articles linked below to determine which option is best for you and your current Autodesk subscription.
  • Contact Support – All forms of help from account management, login, installation, licensing, and product support.
  • Web Support – Our Autodesk Assistant Chat Agent will help through your Autodesk Account
  • Phone Support – Schedule a Call with a Technical Support Agent
Please note that the most efficient way of reaching our support teams is by creating a Schedule a call request.
Remember that web and phone support are only available for customers with an active subscription to one of our products. Subscription users are welcome to contact Technical Support for How-To assistance, troubleshooting, and even to discuss future projects to get started in the right direction before beginning work. At Autodesk, we pride ourselves in putting our customers first, and we’re here to help!
Thank you,
Autodesk Media & Entertainment Support Team!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Replies (12)
Message 2 of 13
mspeer
Hi @hagen.deloss !
What is the best option to report a bug, now that the feedback page has been removed.
Just an example for Maya 2025.1.
Renaming does no longer work for multiple selected objects by using the UI or MEL.
Only every second object will be renamed.
As the related MEL script has not changed since Maya 2024, there could be a bigger general issue for the execution of loops.
Please use the following MEL script to reproduce the issue (You need to execute 1. first before you execute 2.):
// 1. Create 6 cubes and select them
for ($i=0; $i<6; $i++) {
    polyCube;
select pCube1 pCube2 pCube3 pCube4 pCube5 pCube6
// 2. Rename with "test"
renameSelectionList("test")
This can be reproduced within a few seconds, but how to report such issues.
I searched for a long time and even considered applying to the "Autodesk Feedback Community", but was not able to find something related for Maya.
Message 3 of 13
nelsoncruz
@mspeer I would suggest just calling out any bugs on these forums. As for the rename bug you mentioned, we are aware of it and have it in our backlog to address in a future release.
Nelson Cruz
Manager, Software QA Engineering
Message 4 of 13
mspeer
Hi @nelsoncruz !
OK, then I will report future bugs here in the forums.
Thanks for the feedback.
Message 5 of 13
tori.defelice.221
How can I contact Autodesk Technical Support? Giving me a different page then what is giving and not showing up.
Message 6 of 13
Parmenides
Hello, maybe this is the best place to bring this up. I have not able to get tech support through the current ticketing system. I create a ticket but it doesn't go anywhere.
My initial ticket is received and I get a generic response but no one at Autodesk seems to get my email responses and then they close the case. Over the last 8 incidents I have started it is always the same. I respond, and then days later I get an email saying that if I don't respond the case will be closed and then it is, every time. Apparently there is a flaw with the email ticket system.
I tried calling (3x) about this and the person always says someone will call you back but they NEVER call and send an email instead which fails like stated earlier. Very frustrating.
Message 7 of 13
Stephen.Blair
Last case I can find, that I think is from you based on the name I see when I click your icon, is from May. Emails were sent, but no  responses received. Could be a glitch, but the support agent is not a newbie and gets responses on other cases???
// Stephen Blair
// Arnold Renderer Support
Message 8 of 13
Parmenides
Hello Stephen, if you are talking about the forums and messaging, that is fine. This is just the email ticketing system. Thanks.
Message 9 of 13
m_armstrong5
I have been having issues with the search and replace tool. I have posted here: https://forums.autodesk.com/t5/maya-forum/search-and-replace-tool-not-working-as-expected/td-p/13087...
Hopefully this is an issue that Adesk are aware of as it seems to be a bug. I have had other staff experience this also
Kind regards
Message 10 of 13
hagen.deloss
Looks like John S from the QA team replied to you in that thread! let us know if we can help further, and i will post over there if so 😄
Hagen Deloss
Message 11 of 13
jdBAM63
I sure hope technical support requests don't go up since Autodesk only decided to delete... THOUSANDS OF INCREDIBLY IMPORTANT FORUM POSTS!
Genuinely the most infuriating thing as my company is looking to massively re-work our CIVIL 3D template which means lots of questions and for about 1/2 those questions the top 3 search results now don't exist...
Way to remove all of the actual useful answers to questions since everybody know that the built-in help guides are useless for all of the most basic questions.
"At Autodesk, we pride ourselves in putting our customers first, and we’re here to help!"
Yeah... sure, delete all the useful information to help your customers if really putting them first.
Message 12 of 13
late13
Community Visitor
Community Visitor
only need cheaper version.........then you can get more money maybe
Message 13 of 13
number1verybest
I am a hobbyist and now that I have an issue caused by something Autodesk did which wiped my work and can't get support I am not very inclined to upgrade to a paid version since it seems even those with expensive paid subscriptions don't get their problems solved. Hopefully you have better luck.
