How to change Default menu from Rigging to modeling
Recently Maya has started opening the rigging menu on startup instead of the modeling menu. How do I change which menu Maya starts with?
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Are you referring to Layouts? If so, you can change that in your preferences: https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Customizing/files/GUID-D2C8B14B-6AB2-4F6B-AC1E-67154D3FB251-htm.html
Let me know if that answers your question 🙂 If so, consider marking this thread as solved so other forum members can find the answer faster.
Thanks for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Thanks, I tried that but it did not work for me.
The below image shows the option that I am referring to.
It just won't stay on Modeling by default like it used to.
jordan.giboney
Autodesk Support
Autodesk Support
Ah the menu set! Thanks for posting that picture 🙂
If you open up the menu set editor, what order do these items show up in? Here's some more info: Menu Set Editor.
Have you tried resetting your preferences to default recently? You can rename the preference folder for testing so you dont lose any customizations - renaming the folder back to "prefs" after will reinstate your customizations.
Thanks again for being a part of our community!
Jordan Giboney
jordan.giboney
Autodesk Support
Autodesk Support
Also, make sure that the preferences is set to modeling (if thats what you would like it to default to):
Jordan Giboney
