How do I save custom viewport gradient color themes for easy shelf button switching? (MEL script needed)
Meliko
Meliko
I want to create preset color gradients for my Maya Viewport that I can click and change from my shelf instead of going into Windows/Settings-Preferences/ColorSettings every time I want to change the viewport gradient colors.
The closest I found after searching was this post in the forum that had an awesome MEL script that allowed for solid color viewport presets as shelf buttons.
How do I register the color of the viewport in the shelf?
But I need the MEL script that would allow me to input the RGB 0-10 values for TOP and BOTTOM Gradient colors and keep them as shelf button presets?
Any help would be greatly appreciated!
Mel
amaterasu-qbb
Hi! @Meliko .
I thought this was closer to your question so I'm suggesting it. I hope it will be useful for you.
Also, I'm proposing an idea to make it possible to change this in real time, so please vote if you'd like.
Best,
Meliko
Hi @amaterasu-qbb,
Thanks for the reply.  In my post, I actually linked to your post about BG colors as shelf buttons.  It's a good solution that I'll use for quickly changing BG colors with shelf buttons.  I'm hoping there's a way to save Gradient BG themes as shelf buttons also.
I like your idea of real time color changes in viewport like Blender.
Cheers
amaterasu-qbb
Hi! @Meliko .
I just saw that you put the link to my question in your original post. I apologize for that. Unfortunately, I can't solve this problem, but I've summarized everything I've researched.
This is the command when you change Background from 3D View in Color Setting.
updateRGBColor background;
updateColorPrefUI;
from maya.plugin.evaluator.cache_ui import cache_ui_colour_preferences_update
cache_ui_colour_preferences_update()
// I tried both with different colors and the same command returned.
updateColorPrefUI;
This is the command when changing Gradient Top from 3D View of Color Setting.
// Result: scriptEditorPanel1Window|scriptEditorPanel1|formLayout112|formLayout114|paneLayout2|cmdScrollFieldReporter1
updateRGBColor backgroundTop;
updateColorPrefUI;
updateColorPrefUI;
This is the command when changing Gradient Bottom from 3D View of Color Setting.
updateRGBColor backgroundBottom;
updateColorPrefUI;
updateColorPrefUI;
You can see that there are commands that are common to each.
  1. from maya.plugin.evaluator.cache_ui import cache_ui_colour_preferences_update
  2. cache_ui_colour_preferences_update()
  3. updateRGBColor
Checking these with the whatIs command is as follows.
// Result: Unknown
// Result: Unknown
updateRGBColor
// Result: Mel procedure found in: C:/Program Files/Autodesk/Maya2023/scripts/others/colorPrefWnd.mel
// updateRGBColor command
global proc updateRGBColor (string $colorName) {
	string $widgetName = rgbSliderWidget($colorName);
	float $col[];
	$col=`colorSliderGrp -q -rgb $widgetName`;
	float $alpha[]=`colorSliderGrp -q -alphaValue $widgetName`;
	displayRGBColor $colorName $col[0] $col[1] $col[2] $alpha[0];
	// If the User Defined Color Palette window is up, update it
	// We don't check what colour is being updated here because
	// the checking is slower than actually doing the work
	global string $gObjColorPalette;
	if (`palettePort -exists $gObjColorPalette`) {
		initObjColorPalette();
It might be a good idea to ask the same question on the Maya Programming forums.
Also, I think this will involve using an API that does more complex processing than MEL, so it may be difficult to get an answer.
Best,
Meliko
Hi @amaterasu-qbb
Wow. Thanks very much for getting this code!
I echoed commands in script editor but there was nothing when I changed colors in the Color Settings pref panel.  How did you get this code?
I will play around with this and see if I can affect the gradient colors but since I'm not a coder, I don't have high hopes.  Your suggestion to ask in the programmers forum is a good one.
Thanks for taking the time to dive into this.  Much appreciated!
brian.kramer
Hi Meliko,
If I understand correctly you want want to change the viewport background colour using shelf buttons?
Here are 4 little MEL scripts snippets that I think may help:
// Solid 1
displayPref -displayGradient false;
displayRGBColor "background" 0.7 0.7 0.6;
// Solid 2
displayRGBColor "background" 0.6 0.7 0.7;
// Gradient 1
displayPref -displayGradient true;
displayRGBColor "backgroundTop" 0.4 0.4 0.5;
displayRGBColor "backgroundBottom" 0.7 0.8 0.7;
// Gradient 2
displayRGBColor "backgroundTop" 0.5 0.3 0.6;
displayRGBColor "backgroundBottom" 0.5 0.8 0.6;
Paste everything into the Script Editor then select each snippet one at a time. Drag each selection to your shelf.
You should wind up with 4 buttons on your shelf which will change the viewport background.
Hope this helps,
-Brian
Brian Kramer
Software Developer
Meliko
Hi @brian.kramer
THANK YOU!!  This was exactly what I wanted and it's working flawlessly now.
Much appreciated!
