Hot Key Editor
Hot Key Editor
Hot Key Editor
So I am trying to make a custom hot key for Isolate select but it only turns it on. I can't use the regular Shift+I and Ctr+I because I am using those for other things. I made the hot key Shift+Q but using Ctrl+Q doesn't reverse it. How can you make a hot key toggle a feature on and off?
sean.heasley
Hi @Anonymous and welcome to the community!
When you go to assign the key, if you click the little arrow at the top right you'll see an option to "Add and additional hotkey" click that and then make sure one isolate select is set to push down and one is set to on release. That way you can click a button combination to set it as well as release it.
Please let me know if this helps or if you need any more assistance!
