Help, object won't stop showing vertex
I have a mesh that I combined with another, but when I'm finished somehow the mesh won't stop showing its vertex. In all preview mode it still keeps showing vertex. I tried deleting history and re-opening Maya, it still doesn't go away.
sean.heasley
Hi @Anonymous
You say you've checked in all preview modes, do you mean faces/edges/vertices? If not try holding right-click over the mesh and select face to see if that solves your issue.
You can also try deleting your settings/preferences
If those steps don't work can you attach a screenshot of your issue and/or attach the scene file here via dropbox/google drive?
Please hit the Accept as Solution button if my post fully solves your issue, or reply with additional details if the problem persists.
Kudos are greatly appreciated. Everyone likes a thumbs up!
mspeer
Hi!
You may enabled this in Shape: Mesh Component Display -> Display Vertices.
Just uncheck.
If this is not the problem, please upload the scene-file.
sean.heasley
Hi @Anonymous just checking in, are you still having this issue?
pick what rendering your using and restore it to default. happens to me.
Sorry, totally forgot to check back in. I don't remembered how exactly it disappeared, but I think it was because I go into UV Shell. I was doing UV cutting and by the time I realized the vertex disappeared.
