Graphic device does not support OpenGL Core Profile, fallback to OpenGL renderer
Message 1 of 8
We are trying to run Maya 2018 on Windows 7 but below is an error messsage
Initially, Maya 2011 ran on the same PC without qualms.
Graphic device does not support OpenGL Core Profile, fallback to OpenGL renderer.
Stack trace:
ig4icd64.dll!DrvSetContext
OPENGL32.dll!wglSwapLayerBuffers
OPENGL32.dll!wglMakeCurrent
OGSDeviceOGL-16.dll!OGSInitialize
OGSDevices-16.dll!OGS::Devices::Sys::CreateVirtualDevice
OGSRender.dll!OGSRenderer::debugMe
OGSRender.dll!OGSRenderer::initializeOGSDevice
OGSMayaBridge.dll!OGSMayaRenderer::initialize
OGSMayaBridge.dll!OGSMayaBridge::CreateOGSRenderer
OGSMayaBridge.dll!OGSMayaBaseRenderer::initialize
OGSMayaBridge.dll!OGSGeometryEvaluationOverride::~OGSGeometryEvaluationOverride
OGSMayaBridge.dll!OGSMayaBridge::Create3DViewportRenderer
maya.exe!TiteratorWrapperBidir<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator=
ExtensionLayer.dll!Tapplication::start
kernel32.dll!BaseThreadInitThunk
ntdll.dll!RtlUserThreadStart
Replies (7)
Message 2 of 8
sean.heasley
Hi @Anonymous and welcome to the community!
 When you get a chance can you try opening your Maya.env file found in your Maya 2018 folder and add this to it:
MAYA_DISABLE_OPENCL=1
If that doesn't help, there was also a similar issue found in this thread.
The solution there was to delete a dll file which I don't recommend doing until you've tried my above step and back up the files as changing dll files can cause issues with your machine
Here's the solution text from that thread :
C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_250db833a1cd577e )
This Dll file seemed to confuse Maya if there is a GPU or not.
So if there's someone who has this same issue, try to delete  igdrclneo64.dll first!!
Please let me know if anything changes!
Message 3 of 8
Thanks for your prompt response.
I made attempt to locate Maya.env file under C:\Program
Files\Autodesk\Maya2018 by searching for *maya.env* under this directory
and it returned *no found*
The same thing happened with C:\Windows\System32\
A thorough search of *igdrclneo64.dll* didn't turn out any result.
Are there alternative files I can add MAYA_DISABLE_OPENCL=1 to get the same
result? Or what other options are available?
Message 4 of 8
mspeer
Hi!
The Maya.env is in the user directory (Maya preferences).
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Env...
(There is only "ig4icd64.dll" mentioned in Stack trace, not "igdrclneo64.dll",
but without knowing what GPU you use i would not recommend to remove it, you may only try to update the Intel Driver)
Message 5 of 8
sean.heasley
Hi @Anonymous
I looked into this more and its more likely to be a GPU issues. What GPU are you using and does the driver version match with our certified hardware list?
You can find our certified hardware list here!
Message 6 of 8
Thanks for your follow up.
Message 7 of 8
mspeer
Hi!
You need a better GPU for Maya 2018.
You can try setting the Render Engine in Preferences to "DirectX11", but i doubt this helps anything as your GPU does even not support DirectX11 (it supports only DirectX 10).
Sorry your hardware is clearly outdated and may also not work with Arnold cause of needed SSE 4.1 support.
(Can't say without knowing your CPU).
You need newer hardware.
Message 8 of 8
sean.heasley
Hi @Anonymous
@mspeer is correct. An intel integrated card isn't adequate to properly run Maya.
You can find our certified system requirements here!
