I am getting this error whenever I click in FumeFX.mll loaded button in the plugin manager
// Error: file: C:/Program Files/Autodesk/Maya2019/scripts/others/pluginWin.mel line 289: The specified procedure could not be found.
(FumeFX)
Hi @Anonymous
There may be something wrong the fume plugin. Try deleting your settings/preferences and then enable the plugin again.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Hmm ok.
Do you have the most recent version of Fume installed? Also by chance do you have an older version of Maya like 2018 and does fume work with it?
All the best,
Sean Heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Hi there, I have the same error message...
I deleted the preferences and nothing changed 😞
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/hikDefinitionUtils.mel line 204: Found no valid items to add the attribute to.
I have maya 2018
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: (aniMeta)
I have the same problem, already deleted the preferences but its not helping..
Looking forward for help!
same problem when trying to load the glTFExport.py in C:\Users\B\Documents\maya\2022\plug-ins
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: No initializePlugin() function
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: (glTFExport) //
Hi!
Since yesterday I have this same issue in maya 2018.5 importing a FBX created in Max 2018.
I´ve tried:
- to delete Prefs,
- import by MEL:
FBXImport -file "c:/PATH2MyFileHere.fbx";
- open from Max into a new scene in Maya
and nothing!
The error code:
Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/performFileAction.mel line 375:
But the script is OK!
-tried to delete this script, Maya creates a new one with the same error!
Solved!
I´ve changed the directory name from:
laosСupboard
to
laoscupboard
and everything is back to "normal again", including VRImage to EXR Converter too.
Hope this helps others1
LAO
