Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
// Error: file: C:/Program Files/Autodesk/Maya2019/scripts/others/pluginWin.mel
11 REPLIES 11
Message 1 of 12
14230 Views, 11 Replies
I am getting this error whenever I click in FumeFX.mll loaded button in the plugin manager
// Error: file: C:/Program Files/Autodesk/Maya2019/scripts/others/pluginWin.mel line 289: The specified procedure could not be found.
(FumeFX)
11 REPLIES 11
Message 2 of 12
sean.heasley
Hi @Anonymous
There may be something wrong the fume plugin. Try deleting your settings/preferences and then enable the plugin again.
Message 3 of 12
in reply to: sean.heasley
I tried, but still getting error message.
Message 4 of 12
sean.heasley
Hi @Anonymous
Hmm ok.
Do you have the most recent version of Fume installed? Also by chance do you have an older version of Maya like 2018 and does fume work with it?
Message 5 of 12
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 6 of 12
Hi there, I have the same error message...
I deleted the preferences and nothing changed 😞
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/hikDefinitionUtils.mel line 204: Found no valid items to add the attribute to.
I have maya 2018
Message 7 of 12
ramona_h94
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: (aniMeta)
I have the same problem, already deleted the preferences but its not helping..
Looking forward for help!
Message 8 of 12
moiamy
in reply to: ramona_h94
same problem when trying to load the glTFExport.py in C:\Users\B\Documents\maya\2022\plug-ins
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: No initializePlugin() function
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: (glTFExport) //
Message 9 of 12
anilkumarmekala777
in reply to: moiamy
did you find any solution for this?
Message 10 of 12
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 317: (glTFTranslator)
Message 11 of 12
laomusic_arts
Hi!
Since yesterday I have this same issue in maya 2018.5 importing a FBX created in Max 2018.
I´ve tried:
- to delete Prefs,
- import by MEL:
FBXImport -file "c:/PATH2MyFileHere.fbx";
- open from Max into a new scene in Maya
and nothing!
The error code:
Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/performFileAction.mel line 375:
But the script is OK!
-tried to delete this script, Maya creates a new one with the same error!
Message 12 of 12
Solved!
I´ve changed the directory name from:
laosСupboard
to
laoscupboard
and everything is back to "normal again", including VRImage to EXR Converter too.
Hope this helps others1
LAO
