Dear all,
My question is most likely the noobest of all. How in the name of devil himself do I turn off mesh displayed on deselected, shaded models. I somehow turned it on, saved and getting anoyed by ever since. Please help me or I'll loose my sh!@#t
yours
Simon
Hi @Anonymous
You probably accidentally enabled Wireframe on Shaded. You can disable this by going to Shading->Wireframe on Shaded and uncheck it.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Nah... it's not it. The grid is only on one model (the model btw is a ref). I can't post you a screenshot because of legal reasons
Hi @Anonymous
Hmm ok. If the image is under NDA or confidential you can send it to me in a private message which is how we handle classified work.
Let me know if anything changes!
All the best,
Sean Heasley
Thanks but I just figured it out and I'm embarrassed... The issue that was bothering me for past few days was simply cage + smooth on this particular object... I don't know what to say 😄 Maybe we should leave this thread here for future some future doofus who will miss click "2" instead of "3" :D.
Thanks and cheers y'all
Don't feel bad this stuff happens all the time even to veteran artists
Thanks for explaining what you did to solve it! I went ahead and marked it as the solution.
All the best,
Sean Heasley
