Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Custom cam with marking menu
1 REPLY 1
591 Views, 1 Reply
Hi!
I would like to had a custom cam in the marking menue named "Shot_Cam" but I don't know how to code in maya.
If anyone can, could you give me the solution to create something like this ?
I would like to make it to switch to this particular cam if it has already been created, and if not,  create a new perspective cam and rename it Shot_Cam if there is no Shot_Cam already present in the scene, then automatically switch to this cam.
It seems that for exemple the left cam or bottom cam works that way when using the marking menu to switch cams.
Thanks for your time.
1 REPLY 1
sean.heasley
Hi @Anonymous
Having the button make the camera if its not there already would be some complex coding but making a camera that already exists appear in a marking menu is quite easy.
There's lots of resources on making custom marking menus and from there you would just need to add the camera from your scene and be good to go.
