crashes when using arrow key in ctrl+open or any window (probably)
ichigo_yagami
ichigo_yagami
this happens in 2018 and 2019 not sure about 17!! and this happened when i went to open a file wanted to select then boom crash
sean.heasley
Hi @ichigo_yagami
I'm a bit confused by your issue. Is maya crashing when you use an arrow key or is it crashing when you open another window like the Open a File window?
ichigo_yagami
its crashing when opening a window to open a file
sean.heasley
Hi @ichigo_yagami
Ah ok. We actually have an article on this! This issue was fixed with Update 3 of 2018 so you may want to update your 2018 however it shouldn't be occurring at all on 2019.
If the problem continues or upgrading is not an option, this may be an indication of an issue relating to the Operating System. Follow these steps to avoid the crashing:
  1. Shut down Maya, reset Maya Preferences, restart the computer
  2. Switch Maya Preferences to OS Native file browser:
file dialog
Windows > Settings/Preferences > Preferences > Files/Projects > File Dialog, OS native > Save
Map (using mapped network drives) a drive to a shared folder on the server instead of the root of the computer. Using Mapped network drive avoids the root selection in file browser avoids the crashing.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @ichigo_yagami
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
