As the title says, when I use a brush from the paint effects folder in the content browser, they seem to come without a texture applied. Is this normal or is something wrong?
Looking at the attributes of one of the paint effects, there is a texture file attached, but as far as I can see, it does nothing
I'm using Maya 2017.
Example pic:
Solved by mspeer. Go to Solution.
Hi!
Paint Effects don't behave and display like other mesh objects in Maya.
To change this you need to convert them to Polygons.
Modify -> Convert -> Paint Effects to Polygons
Read more about Paint Effects in Maya Online Help / Documentation.
@mspeer wrote:Hi!
Hello Mspeer,
Thanks that worked perfectly. I'll look in to it more via documentations.
Cheers
