Can't login with Autodesk ID SSO on Linux
josewardMARP7
Message 1 of 46
josewardMARP7
As the title says, I can't log into Maya using SSO Autodesk ID on Linux. Everything has been installed correctly to my knowledge, but I'm happy to answer specific installation questions if someone more knowledgeable thinks it is relevant.
The program opens fine, but when I select, "Sign in with your Autodesk ID", the window just closes. Selecting" Enter a serial number" or "Use a network license" does not crash the app. Authentication services are running properly and are up to date.
I have found this thread, but the solution provided is exclusive to Windows.
I am running Fedora Linux 39.
If anyone knows a solution to this problem or potential rabbit holes to explore, let me know!
Replies (45)
Message 41 of 46
meepzh
Thank you for your efforts, jimmy_christensenMSURY. I was able to reproduce your success in the AUR. The software versions that I used were:
  • adlmapps 31.0.4
  • adsklicensing 15.1.0.12339 (15.4.0.13093 also works)
  • adskidentitymanager 1.15.3.5 (pre-1.15 crashes on Arch Linux)
  • maya 2026.0
It appears that the flow is that Maya interfaces with adsklicensing, which checks for any version of webkit2gtk3 through the rpm command. Once it determines that that requirement is satisfied, it will then search for /etc/pki/tls/certs/ca-bundle.crt or error out accordingly. I am not sure how this impacts systems that already have that file. Following that, it will launch the Identity Manager, which uses webkit2gtk, from where the user logs in. Upon a successful login, Maya will launch. On Arch Linux, the error logs are found in /tmp, which corroborate these workarounds.
Message 42 of 46
david.ostler2WSX9
I was able to get passed  "ERROR: Error Information: Maya 2026 : [IDSDK] 3073: The PC has not installed WebKitGTK yet, please install WebKitGTK." By doing the following, very similar solution to @jimmy_christensenMSURY.
sudo apt install rpm
cat > ~/mk_webkit2gtk3_dummy.sh <<'Bash'
#!/bin/bash
set -e
cat > webkit2gtk3.spec <<'SPEC'
Version:        1
Release:        0
Summary:        Dummy Provides: webkit2gtk3 for Autodesk Licensing
License:        Public-Domain
%description
Empty placeholder so rpm -q webkit2gtk3 returns success.
%files
SPEC
rpmbuild -bb --define "_rpmdir $(pwd)" webkit2gtk3.spec
sudo rpm -i --nodeps --force x86_64/webkit2gtk3-1-0.x86_64.rpm
echo "Dummy RPM installed."
Bash
bash ~/mk_webkit2gtk3_dummy.sh
Now I'm getting the below window but no browser window opens up.
At first I couldn't get a browser window to open.  I restarted my machine and it worked, I assume that there is an easier way but it worked and a browser opened and I was able to authenticate through Autodesk.  Then I ran into this issue:
In order to register AdskIdentityManager so that Ubuntu would recognize it as an app I did this:
/opt/Autodesk/AdskIdentityManager/Current/AdskIdentityManager --register
I noted that the file it created in ~/.local/share/applications/com.autodesk.AdskIdentityManager.desktop had the AdskIdentityManager's version number in the path instead of "Current" so I updated that file to future proof it.
Then I  updated the database and set adskidmgr as the default app:
# make sure the desktop database picks up the new entry
update-desktop-database ~/.local/share/applications
# set it as the default for this scheme
xdg-mime default com.autodesk.AdskIdentityManager.desktop x-scheme-handler/adskidmgr
And now Maya 2026 works on Ubuntu 24.10
Seems like there are still a few little quirks like complaining about not having access to the internet:
There are also some new errors I don't recall seeing on Maya 2024, here's my startup output:
Detected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
[2025-04-29 23:57:20.156] [warning] cannot create Service Data folder at path /var/lib/Autodesk/CER, Access to file denied: /var/lib/Autodesk
Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Initialized VP2.0 renderer {
  Version : 2016.11.62.12. Feature Level 5.
  Adapter : NVIDIA GeForce RTX 4090/PCIe/SSE2
  Vendor ID: 4318. Device ID :
  Driver : 4.6.0 NVIDIA 560.35.03.
  API : OpenGL V.4.6.
  Max texture size : 16384 * 16384.
  Max texture coords : 32
  Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
  Shader compiler profile : (Best card profile)
  Active stereo support available : 0
  GPU Memory Limit : 24564 MB.
  CPU Memory Limit : 119992 MB.
  MultiDraw consolidation : enabled
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
 0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 3.0 CUDA 12.6.65.
 Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info cl_khr_external_semaphore cl_khr_external_memory cl_khr_external_semaphore_opaque_fd cl_khr_external_memory_opaque_fd
 Selected matching OpenCL Platform: NVIDIA Corporation NVIDIA CUDA OpenCL 3.0 CUDA 12.6.65.
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device NVIDIA GeForce RTX 4090.  Device Type: GPU  Device is available.
Running these two lines fixed the permissions issue, it's just me on this machine:
sudo mkdir -p /var/lib/Autodesk/CER
sudo chown -R $USER:$USER /var/lib/Autodesk
And I removed "LC_ALL=C" from my Maya.env and that fixed the "UTF-8" issues.
I then created a fresh account to be to see what the default Maya.env looked like and it was empty.  I removed everything from my Maya.env and Maya starts fine without any extra complaints.  The entries must have been carried over from a previous Maya version.
Message 43 of 46
blendernoob64
I tried david's tutorial above on Fedora 41 for Maya 2024 and it worked perfectly. I had to make a fake RPM and then update my desktop entries, then Maya would launch perfectly. Now I no longer have to keep uninstalling 2024's identity manager just to use Maya for a day. I wonder if Fedora 42 will still work. We will see.
Message 44 of 46
david.ostler2WSX9
After using Maya for a few weeks now it seems pretty solid.  The only issue I've run across is that the Arnold Render View will not open back up once it has been closed.  The only way to get it to open again is to restart Maya as far as I can tell.  Not a huge deal, I just minimize the window instead of closing it but still a bit tedious as I often make the mistake of closing the window.  Just wondering if others are seeing the same issue on the non-approved linux flavors?
Message 45 of 46
blendernoob64
I just tried the fix on Fedora 42 and it worked! You will have to reinstall the dummy rpm after updating, but everything should be good afterwards. Also you will need to run on an X11 DE so no Wayland sessions until Autodesk adds proper wayland support.
Message 46 of 46
blendernoob64
Another update, on Fedora 42, I was able to launch Maya 2024 in the KDE and GNOME wayland session, and with the Identity Manager fix. I do not know if Autodesk Updated something in the background, or XWayland fixed something, but it would be nice to have this confirmed with other setups. My only other guess is that maybe the Identity Manager checked me in when I was running an X11 session and just never bothered to check in again?
