Unable to sign in to Maya with Autodesk ID on initial launch (education 1 year download)
Message 1 of 15
Hello! I've recently downloaded Maya 2020 education edition with my university email. I'm running Windows 10, 64 bit.
When I try and start Maya, both the launcher (see pic below) and Output Window open, but I'm unable to sign in to activate the product. As soon as I click "Sign in with your Autodesk ID," the launcher closes and nothing happens. I've tried reopening Maya and the same thing happens over and over again.
I'm able to click "Enter a serial number" or "Use a network license" and it shows the two screens below respectively, but I still can't Sign in with my Autodesk ID.
I've also tried uninstalling/reinstalling the product multiple times, but always have the same problem.
I'd appreciate any advice or help, thank you!
Replies (14)
Message 2 of 15
vahn.chua
Autodesk Support
Autodesk Support
@Anonymous Welcome to Autodesk Community.
Have you tried to update the AdSSO (Autodesk Single Sign-On) component? you can download this from your Autodesk Account.
Vahn Chua
Message 3 of 15
juanca9945
Community Visitor
Community Visitor
That doesn't work. Although, AdSSO is not available in the autodesk account.
Message 4 of 15
So how do you know it doesn't work if you don't have the update to install in the first place?
FYI it will be under "Updates and add-ons" and it's also available here... Autodesk Single Sign On Component (AdSSO) Update for 2020 & 2021 product versions | AutoCAD 2021 | A...
Message 5 of 15
mdavis22569
@Anonymous
Were you able to get this resolved?
Mike Davis
Message 6 of 15
Hello
Did you manage to resolve this? I'm having the same problem and I really wish to resolve this 🙂
Message 7 of 15
leowarren34
Hi @Anonymous,
Have you followed this article: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Software-version-2020-or-higher-crashes-after-clicking-Sign-in-with-your-Autodesk-ID.html ?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 8 of 15
mdavis22569
@Anonymous just checking again to see if you got this resolved
Mike Davis
Message 9 of 15
glorianguyen1102
Community Visitor
Community Visitor
this still doesn't resolves anything :((
Message 10 of 15
espora3d
Observer
Observer
Hi, is a trouble with the adsso. i resolve installing this https://knowledge.autodesk.com/sites/default/files/adsso_2022_1_64-bit-update_installer.zip .
uninstall and reinstall, and everything work fine.
Message 11 of 15
mdavis22569
For this .. You need to make sure all of the update are installed ... and all Autodesk updates are installed.
MCD
Mike Davis
Message 12 of 15
201912009WUXFG
Community Visitor
Community Visitor
I've also been trying to solve this issue since yesterday, but this solution helped me. I'm able to use my maya now!! Thank you so much.
Message 13 of 15
kpickett2QST8
Community Visitor
Community Visitor
ran into this as well, the link in the solution no longer works but
i'm on mac and opening Activity Monitor, killing all Adsso processes, then installing the pkg found at this link, and trying to open Maya again, fixed it for me.  (Haven't tried but i think the equivalent for pc might be this link)
(thank you espora for that solution!!)
Message 14 of 15
deniscc525
Thanks, that solved it for me. In the installation set up I clicked remove and then installed it fresh.
Message 15 of 15
Juiceinablender
I have the same problem but i did all of the steps and no luck, help. I installed maya 2024 a few months ago with success, then decided to Uninstall a while ago but then reinstall it. Now this time I can't login, I tried every solution and none worked. I can't even login in autodesk access
