Can't load USD plugin
BrianHanke
Message 1 of 11
BrianHanke
I'm not able to load the USD plugin in Maya Indie 2022 on Windows 10. I get the following error message:
Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pluginWin.mel line 316: The specified procedure could not be found.
Any ideas what the problem might be? Thanks!
Replies (10)
Message 2 of 11
BrianHanke
Still perplexed by this. I did some more reading on this topic and I feel like I might need some other USD-related stuff installed, or set up some PATH variables in Windows, or both? It's not at all clear if MayaUSD is a standalone system or just an interface between Maya and an existing USD installation. The Maya docs make it seems like you just load the plugin and that's it, but it's definitely not working for me. I'm wanting to test this as a bridge between Houdini Solaris and Maya. Solaris outputs a working USD file just fine (confirmed by opening it in Clarisse), but Maya won't even load the plugin, let alone let me open a file.
Message 3 of 11
BrianHanke
Removed my original "solution." Turns out it was much simpler:
I had Nuke in my Windows PATH.
Removed that and all is working fine now. Must have been a conflict with Nuke's Python stuff.
Message 4 of 11
ckingT5S5B
I'm running into the same problem. I don't use Nuke so it must be something else that is conflicting.
Message 5 of 11
ckingT5S5B
My problem turned out to be a conflict with the NVIDEA USD tools.
Message 6 of 11
dflipb
how did you fix it?
Message 7 of 11
mishdivy
Observer
Observer
If you have Omniverse to Maya Connector installed just unload it through the plug-in manager and restart maya.
Message 8 of 11
dflipb
Hemmm. Maybe that was it. I haven't been back to try it, but I was having a problem with omniverse in that I tried loading it into my D drive. Apparently it can only be loaded on the C drive at the time of this writing, but it doesn't say that anywhere in the documentation.
Message 9 of 11
mishdivy
Observer
Observer
Interesting, I think I chose C drive as the data path for Omniverse, but I chose an external drive for Library and Content Path and it still works for me.
Message 10 of 11
alek.lazarov
Community Visitor
Community Visitor
I run into the same issue,i.e usd plug in not loading with the same error message but I don’t have NUKE installed on my laptop.I do have a couple other like davinci, substance pt ,substance dz .Which one could be the culprit in my case?
Message 11 of 11
jchampTBPRE
Observer
Observer
Thanks mate, this did the trick!
