Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Noob question Xgen base poligon edit
4 REPLIES 4
bunyaminbulak
359 Views, 4 Replies
I made eyelash but after everythings done i just realise my base poligon need way much thicknes .I'm following a tutorial  ,the guy who made the tutorial said "you can change base polygons later" but he didn't show how to do it .So i need your help .
here is ss for explain myself better ; https://ibb.co/5hWrVn1
Labels (1)
4 REPLIES 4
if i need to give more information please let me know
@mspeer sorry to bother you sir , maybe this problem is not even worth to send post but i realy need help
mspeer
in reply to: bunyaminbulak
Hi!
I am not sure what you mean with thickness.
If this is Classic XGen and not Interactive Groom, then you can use In XGen Editor
Descriptions -> Bind Patches -> Add Selected Faces
You can also create a new mesh and use a wrap deformer to follow the original geometry.
I don't recommend to edit the mesh where you already created XGen on (even not renaming it).
bunyaminbulak
in reply to: mspeer
Descriptions -> Bind Patches -> Add Selected Faces is what i looking for .You are life saver sir .Thanks a lot appreciated.
