Can't Get Redshift plug-in to work on Maya 2024
vdickra153
Message 1 of 11
vdickra153
Redshift works on C4D on my Mac Studio, but for some reason it does not work for Maya 2024
Replies (10)
Message 2 of 11
damaggio
load it in the plug in manager.
Message 3 of 11
warnold2
more info would be helpful to understand what doesn't work.
does the plugin load, are there any messages, in either the script editor or if one launches Maya from the terminal is there any output to the Terminal window
from a Terminal Window, launch Maya as:
/Applications/Autodesk/maya2024/Maya.app/Contents/MacOS/Maya
Wayne Arnold
Developer
Message 4 of 11
vdickra153
Hi Wayne,
Thanks for the reply
I launched Maya from the terminal and did not notice any Redshift loading errors.
However, from Maya's script editor: // Warning: file: /Applications/Autodesk/maya2024/Maya.app/Contents/scripts/others/supportRenderers.mel line 76: The renderer "redshift" used by this scene, is not currently available. The "arnold" renderer will be used instead. To prevent this message from being displayed in the future, set the environment variable: MAYA_NO_WARNING_FOR_MISSING_DEFAULT_RENDERER=1
I have installed Redshift and did exactly as per their (Maxon's tech support) spec.
Did the following:-
1)
Applications/Autodesk/Maya2024/Maya/Contents/Modules/redshift4maya.mod
2)
Copy redshiftRenderer.xml to Maya's rendererDesc directory (required for Maya command-line rendering)
Copy the file /Applications/redshift/redshift4maya/common/rendererDesc/redshiftRenderer.xml to /Applications/Autodesk/<MAYAVERSION>/Maya.app/Contents/bin/rendererDesc/
Still won't work and get the "Maya's script editor: // Warning", as shown above
Message 5 of 11
vdickra153
Hi Sgt_Rock,
Redshift does not show up in Plug-ins window.
I tried browsing to the Redshift folder, and it shows up, check mark, but when you restart Maya, its not there anymore.
I tried adding it to the Plug-ins folder (redshift4maya.bundle), then in Plug-ins window Redshift shows up, but cant checkmark it.
Message 6 of 11
warnold2
is Redshift plugin a Universal Binary 2 (Intt64+arm64) binary ?
from terminal can run the "file" command to see what the architectures are included in the file.
ie: file redshitft4maya.bundle/Contents/MacOS/redshift4maya
are you running Maya as native arm64 or running under Rosetta2
Wayne Arnold
Developer
Message 7 of 11
vdickra153
I don't see why I have to go through all this checking as neither Maya or Redshift were "custom" installed, nor did I make any alterations to where they downloaded, etc, etc. They are standard apps and all you do is install and use. That's how I have used all my apps on an Apple.
Thanks for all the suggestions/recommendations
I guess I will have to delete Maya and Redshift and start again.
One thing I forgot to mention that Maya 2023 worked with Redshift.
Message 8 of 11
warnold2
Maya 2023 was Intel only build running under Rosetta2 on an Apple Silicon Mac based machine.  if your build of redShift for Maya 2024 is Intel only then one would need to run Maya 2024 as Intel in order for the plugin to load.  which was why I suggested to check what architecture your plugin was and if there is an updated release.   I don't have redShift available to check
to run Maya as intel process on Apple Silicon
arch -arch x86_64  /Applications/Autodesk/maya2024/Maya.app/Contents/MacOS/Maya
in reply above you did change "<MAYAVERSION>" to the actual maya2024 path
Wayne Arnold
Developer
Message 9 of 11
warnold2
what version of Redshift are you using.  from https://help.maxon.net/r3d/maya/en-us/#html/Release+Notes+3.5.html?TocPath=_____2
there was on updated versionb
3.5.19 (2023.09)
Release Notes
  • [Houdini] Added support for Houdini 19.5.716 and dropped support for 19.5.605
  • [Hydra] Added support for Solaris 19.5.716 and dropped support for 19.5.605
  • [All] Fixed corruption and crash bugs that could occur when rendering scenes with photons, IPC and SSS
3.5.18 (2023.09)
Release Notes
  • [Maya] Fixed support for Maya 2024/macOS on Apple Silicon hardware
Wayne Arnold
Developer
Message 10 of 11
vdickra153
Message 11 of 11
Stephen.Blair
Then Maya is not finding the module file.
// Stephen Blair
// Arnold Renderer Support
