Hi Wayne,
Thanks for the reply
I launched Maya from the terminal and did not notice any Redshift loading errors.
However, from Maya's script editor: // Warning: file: /Applications/Autodesk/maya2024/Maya.app/Contents/scripts/others/supportRenderers.mel line 76: The renderer "redshift" used by this scene, is not currently available. The "arnold" renderer will be used instead. To prevent this message from being displayed in the future, set the environment variable: MAYA_NO_WARNING_FOR_MISSING_DEFAULT_RENDERER=1
I have installed Redshift and did exactly as per their (Maxon's tech support) spec.
Did the following:-
1)
Applications/Autodesk/Maya2024/Maya/Contents/Modules/redshift4maya.mod
2)
Copy redshiftRenderer.xml to Maya's rendererDesc directory (required for Maya command-line rendering)
Copy the file /Applications/redshift/redshift4maya/common/rendererDesc/redshiftRenderer.xml to /Applications/Autodesk/<MAYAVERSION>/Maya.app/Contents/bin/rendererDesc/
Still won't work and get the "Maya's script editor: // Warning", as shown above
