Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Why plugging a texture into noise amplitude does absolutely nothing?
5 REPLIES 5
dennis3V39Z
139 Views, 5 Replies
I applied a noise texture as deformation on a flat surface, and I wanted to apply a second map in the amplitude channel using a gradient as a transition effect for that deformation.
Nothing is happening though. What am I doing wrong here? Do I need to do some data conversion?
5 REPLIES 5
sepu6
in reply to: dennis3V39Z
Are you using the texture deformer? can you show a screenshot that shows the issue? Or even better a file.
rsettleXFGZK
Yes it's a texture deformer. I've attached the project.
edit: sorry, my maya login made me post through a different account without realizing.
damaggio
Ramp.jpgI just applied a ramp to the  color gain so I can still tweak the amplitude.
The ramp will give you more control than a texture mask.Also center your Uvs
I hope that helps  Dennis.
damaggio
in reply to: rsettleXFGZK
Did that work Dennis?
dennis3V39Z
in reply to: damaggio
I was able to recreate this. Thank you for your help!
