Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Autodesk application manager files - can they be deleted?
2 REPLIES 2
BenediZ
1805 Views, 2 Replies
I have several big files of Autodesk Application manager
e.g.
"Autodesk_Maya_2019_1_Update_dlm.sfx.exe"
I think they are only part of installation and can be deleted?
Because they take a lot space...
EDIT:
Furthermore I found 18,6GB of space used by
C:\Autodesk\Autodesk_Maya_2019_1_Update_dlm
+ Autodesk_Maya_2018_6_Update_dlm
+ Autodesk_Maya_2018_2018_EN_JP_ZH_Win_64bit_dlm
+ C:\Autodesk\WI (inside again maya2016+2018+2019 = 6GB)
and similar files in this folder
Are these only installers and can be deleted?
2 REPLIES 2
sean.heasley
in reply to: BenediZ
Hi @BenediZ
Yes those are files you download to run the install so you should be able to remove them. Just be careful to only remove them and not any other files that may affect Maya.
sean.heasley
in reply to: sean.heasley
Hi @BenediZ
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
