Hello, I am about to buy a new laptop on which I can learn and use Maya. There is a big difference in price between 8 GB RAM and 16 GB RAM so I would like to be sure, do I really need 16 GB RAM to use MAYA successfully?
Solved by mspeer. Go to Solution.
Solved by sean.heasley. Go to Solution.
Hi @Anonymous and welcome to the community!
Our recommended system requirements say 8 GB of RAM (16 GB or more recommended)
Ram will really help with running multiple programs say Maya and Unreal Engine or Photoshop, Marmoset etc but it will also help with performing heavy renders like with Vray.
You will be able to do all of this well enough with 8GB of RAM so you don't need 16GB but if you can afford it I'd recommend using 16 especially if you plan on having multiple programs open while working in Maya !
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi!
To learn Maya 8Gb is enough, but to use it (in terms of working) to do any project 16 GB is highly recommended.
