2019 Script Editor
2019 Script Editor
2019 Script Editor
When I open Maya 2019 (Student Version), script editor show me some errors. I attached the screenshot. I want to fix this issue. Can you tell me how can I fix this error? Thank you.
sean.heasley
Hi @Anonymous  and welcome to the community!
Are those causing any problems for you?
They seem to be warnings about Arnold not necessarily error messages. You could try unloading and reloading your MTOA plugin and/or make sure you are working with the most recent version of Arnold.
mspeer
Hi!
I can't see any errors, just some warning, this is normal.
Just ignore this.
No those warnings are not making any problem for me but I just want to clear those warnings. I already tried your mentioned methods also I tried clean uninstallation and reinstallation of Autodesk Maya.
sean.heasley
Hi @Anonymous
Like @mspeer  said these are normal and can be ignored. You should only worry about things like this in the script editor if you're experiencing problems and/or crashes etc in Maya.
Ok understood. Thanks for your help.
Got it. Thanks for your help. I appreciate you.
