Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
isolate RGB PP red channel and drived by force attributes from n particles
3 REPLIES 3
mx51
419 Views, 3 Replies
mx51
Observer
Observer
Hi everyone
This is my first time here and It's my first time dealing with vector.
I would like some help please. Here what I trying to do.
In n particles I want to connect force attributes to RGB PP to display the force inside the particle.
It can be done in node editor and works but I need some extra.
I would like to assigned the force to the R channel only of RGB PP but I can't get the correct expression
for example I tried -> nParticleGenTurbShape.rgbPP = {nParticleGenTurbShape.force, 0, 0}
but I get // Error: Line 0.67: Cannot cast data of type vector[] to vector.
Someone can help me with that. i will have another problem but this is my main issue currently.
Thanks in advance
Hi everyone
Thanks in advance
Labels (4)
3 REPLIES 3
hamsterHamster
in reply to: mx51
hamsterHamster
Curly brackets {} are for the arrays, while your PP attribute is a vector.. use <<R,G,B>> instead. And then, the .force seems to be an array of several vectors, while the R component you want will be most likely a single float type number.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
,,,_°(O__O)°_,,,
mx51
in reply to: hamsterHamster
mx51
Observer
Observer
Thanks for the reply. Yeah that's make sense. Do you have an idea to write this expression  ?
hamsterHamster
in reply to: mx51
hamsterHamster
No, I have no particular idea, because it is unclear what force did you mean; there are many, depending of the dynamics setup, and you want to put them under one float, like compressing Mona Lisa painting to a line. 😄 If I were you, I'd start by learning/printing out what is within that .force array, then decide just one thing which will drive the R channel.
,,,_°(O__O)°_,,,
,,,_°(O__O)°_,,,
