Hi everyone
This is my first time here and It's my first time dealing with vector.
I would like some help please. Here what I trying to do.
In n particles I want to connect force attributes to RGB PP to display the force inside the particle.
It can be done in node editor and works but I need some extra.
I would like to assigned the force to the R channel only of RGB PP but I can't get the correct expression
for example I tried -> nParticleGenTurbShape.rgbPP = {nParticleGenTurbShape.force, 0, 0}
but I get // Error: Line 0.67: Cannot cast data of type vector[] to vector.
Someone can help me with that. i will have another problem but this is my main issue currently.
Thanks in advance
Curly brackets {} are for the arrays, while your PP attribute is a vector.. use <<R,G,B>> instead. And then, the .force seems to be an array of several vectors, while the R component you want will be most likely a single float type number.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
Thanks for the reply. Yeah that's make sense. Do you have an idea to write this expression ?
No, I have no particular idea, because it is unclear what force did you mean; there are many, depending of the dynamics setup, and you want to put them under one float, like compressing Mona Lisa painting to a line. 😄 If I were you, I'd start by learning/printing out what is within that .force array, then decide just one thing which will drive the R channel.
,,,_°(O__O)°_,,,
