Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Snap to pivot
3 REPLIES 3
RPYTHON
712 Views, 3 Replies
Snap to pivot
Is there a way to snap locator to an objects pivot? Of course, I can do it with MEL, but I'm interested in the standard options.
Tags (2)
3 REPLIES 3
Kahylan
in reply to: RPYTHON
Hi!
Two easy ways I can think of:
1) Use a parent constraint with the "Maintain Offset" option turned off.
2) Parent the object you want to snap under the other object and set translation and rotation to 0.
I hope it helps!
stephenkmann
Turn on the selection handle of the first object. and hold v and snap the locator to it
dinofiguera
Select your locator, shift select your target,  go to MODIFY ----> Match transformations
you can choose to match only the translations, the rotations, the scale, or even only the pivot of your locator...
Technology Administrators
