Is there a way to snap locator to an objects pivot? Of course, I can do it with MEL, but I'm interested in the standard options.
Solved by dinofiguera. Go to Solution.
Solved by stephenkmann. Go to Solution.
Solved by Kahylan. Go to Solution.
Hi!
Two easy ways I can think of:
1) Use a parent constraint with the "Maintain Offset" option turned off.
2) Parent the object you want to snap under the other object and set translation and rotation to 0.
I hope it helps!
Turn on the selection handle of the first object. and hold v and snap the locator to it
Select your locator, shift select your target, go to MODIFY ----> Match transformations
you can choose to match only the translations, the rotations, the scale, or even only the pivot of your locator...
