Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Rotate one object around another object
6 REPLIES 6
2660 Views, 6 Replies
How can i rotate an object around another object (not centre pivot).
6 REPLIES 6
mspeer
Hi!
1. Parent it to an other object, or Group.
2. Modify Pivot position.
Please read the Maya Online Help / Documentation for more details.
in reply to: mspeer
Thanx for the reply!
But how to modify the pivot position?
Hey there, below I made a quick screencast for you to show how to go about it!! (:
Either you put the center pivot of the object on the other object in which it rotates around from or you add a group node above the object and change the group node's center pivot instead! 🙂
Hope that helps out! I actually have a rigging course that is 14+ hours and over 120+ lectures that should help you out for beginner stuff all the way to more advanced techniques!!
Link is below, wish you the best of luck!
MAYA RIGGING COURSE
mspeer
Hi!
Use Move Tool and hit hotkey "D" or "Insert".
Thanks a lot man..The video really helped a lot!!
Technology Administrators
