@Anonymous
Is the history on the joints deleted? Are their rotations frozen before re-targeting?
Hi Faline,
the History is on the target joint should be deleted ?! What do you mean ?
And where should i freeze the rotations ?
Someone told me also:
You might run a script that parent constraints (with Maintain Offset off) the Red hand to the Mocap source’s hand, then bakes the red hand...
What do you think ?
Thank you very very much for your help Faline i really appreciate it!
Jan
@Anonymous
I'm referring to Edit > Delete by type > History sometimes this can clear some issues up. I'd be happy to take a look at your scene file, if you would like to send it to me in a private message.
More than happy to take a look and provide further insight. =] Let me know!
Cheers
I know this thread is long old, but I've recently came across the same issue and resolved it. Of your first image, your source motion fingers are perfectly straight; we can call this T-pose of fingers. Whereas your red target skeleton is more relaxed and in a natural pose; we can look at that as an A-pose for fingers. Instead of focusing on zeroing out the rotations, try to take your target skeleton and match the T-pose of the source skeleton. It is more important that the source and target skeletons are matching in their poses. Also another gotcha, make sure to do your pose edits after you've unlocked your target skeleton definition, and re-lock it when the posing is done, assuming you're using HumanIK.
