I'm a beginner just started rig.
I applied the blend chef in maya2018 and connected the controller to the blind shape using the drive key.
And when I press "s" for animation,
Blend shape does not apply and there is a strange problem.
If you check shape editor, the blind shape slider works fine, but the mesh of the face has not changed.
I searched Google to solve this problem and found that I should change the mode from Evaluation Toolkit to DG. If you change the parallel to DG, the expression moves well to blend shape.
But I have to send this file to someone else, and I don't know what mode they are using. Is there a way to resolve this issue without replacing it with a DG?
It's my first time using this Forum. Please let me know if there is anything wrong.
I used a translator.
