Announcements
How to change attribute order in Channel Box?
litote
Message 1 of 17
litote
I have created a few custom attributes (Edit-Add Attribute) in Channel Box. Is there a way to re-order them?
Replies (16)
Message 2 of 17
Unfortunately, I don't believe they have implemented a good way to do this. However, you can delete the attribute then use the "Undo" function (Ctrl+z) to bring it back, it will reappear at the bottom of the list. This is an annoying way to do it, but it's the only way I know of.
Message 3 of 17
litote
Thanks, it is a solution.
Message 4 of 17
You can try it with this tool too: https://github.com/jlararigger/jlr_sort_attributes
You only have to select one or several attributes in the channel box and in the Edit menu of the channel box choose Move Up Attr or Move Down Attr.
Message 5 of 17
JuanBernardo29
The other way is to save the file as ascii .ma and edit the order of the attributes in any text editor, and sometimes that's the only practical way
Message 6 of 17
Editing the .ma file by hand? deleting and creating the attrs again? what If they are connected to other attrs through expressions or sdk? Is there honestly not a better way to do this in maya...?
Message 7 of 17
JuanBernardo29
Well, it's something I never understood why they never implemented, a simple way to manage attributes, but it's quite easy  to do it editing .ma file in text editor, no problem with connections or expressions, you're not changing any relationship, just display order
Message 8 of 17
stephenkmann
I'm working on releasing my channel tools for quickly moving and connecting channels.
sm_channel_toolssm_channel_tools
here is a long boring overview of the tools and how to use them:
https://youtu.be/Qttjt-s6gtY
Message 9 of 17
Sure! opening my .ma file on a text editor an manually edit the code of my file is easy enough but cmon....I wonder why houdini is eating away maya users...
Message 10 of 17
derek_k_annan
Thanks for this. its works perfectly
Message 11 of 17
stephenkmann
if you are interested. i made a tool to help move channels around. change their types, etc etc. you can get it here:
https://smannimation.gumroad.com/l/tuTQp
here is the first video I made about how to use it. but I try and update it
Message 12 of 17
luisandro.garza
How does this work? Do I just copy the code to the script editor?
Message 13 of 17
stephenkmann
put the script in your documents/maya/scripts directory
and then in the script editor ( python tab)
run the following
import sm_channel_tools
sm_channel_tools.UI()
Message 14 of 17
luisandro.garza
Yeah I tried that. Doesn’t seem to work properly. I’m using maya 2022.
Message 15 of 17
stephenkmann
Are you getting any errors?
Is the window not opening?
Can you give me more info?
did you download the latest version from Gumroad?  should be 8.5
Message 16 of 17
luisandro.garza
[image: image.png]
This is the best I can do. I'm not too good at python, but I do have
experience running scripts in Maya. I've tried several script folders.
[image: image.png]
[image: image.png]
Message 17 of 17
stephenkmann
looks like your images didn't get posted.
Do you have python scripts in other directories?
You should be able to drop it into your Maya/2020/prefs/scripts/
and that's it.
