Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Blend Skin trouble
3 REPLIES 3
tori.defelice.221
49 Views, 3 Replies
Blend Skin trouble
I placed the joints into the model and when I go to skin both the skeleton and model together, I keep getting this error.
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/createSkinCluster.mel line 244: You must select at least one joint. //
# Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pythonRunTimeCommand.mel line 15: RuntimeError: file C:\Program Files\Autodesk\Maya2022\Python37\lib\site-packages\maya\internal\nodes\skincluster\cmd_create.py line 202: Error occurred during execution of MEL script
file: C:/Program Files/Autodesk/Maya2022/scripts/others/createSkinCluster.mel line 244: You must select at least one joint. #
3 REPLIES 3
If you could do a screen recording of what you're doing that might be helpful. But here are a few guesses:
  1. Are you using shift select so both the joint and mesh are selected at once?
  2. Are you maybe selecting a group that contains the joint rather than a joint?
  3. Try resetting the settings in the bind skin menu.
@jmreinhartThanks for help. I already figure out what I did wrong. Thanks again.
Technology Administrators
