I placed the joints into the model and when I go to skin both the skeleton and model together, I keep getting this error.
// Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/createSkinCluster.mel line 244: You must select at least one joint. //
# Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/pythonRunTimeCommand.mel line 15: RuntimeError: file C:\Program Files\Autodesk\Maya2022\Python37\lib\site-packages\maya\internal\nodes\skincluster\cmd_create.py line 202: Error occurred during execution of MEL script
file: C:/Program Files/Autodesk/Maya2022/scripts/others/createSkinCluster.mel line 244: You must select at least one joint. #
Solved by jmreinhart. Go to Solution.
If you could do a screen recording of what you're doing that might be helpful. But here are a few guesses:
@jmreinhartThanks for help. I already figure out what I did wrong. Thanks again.
