Use key frame animation after a motion path
kjw.chiu
kjw.chiu
I currently have a group of joints (bound to objects) moving along a motion path as desired. At the end of the path, I would like to switch to key frame animation. I tried moving the group and creating a key frame there a few frames after the motion path animation ends, but it disconnects from the motion path and stays in place, even after I go back to frame 1. How can I switch to key frame animation after the end of the motion path animation, but still keep it connected to the motion path?
Thank you.
mspeer
Hi!
In the Channel Box there are 2 Blend attributes added below the animated object.
Set the values for the Blend attributes to "1" for 100% influence by the Motion Path and to "0" for 100% influence by the keys.
kjw.chiu
Awesome! Thank you.
