I was wondering when applying a constraint on an object, ex a parent constraint, does it prevent the transformation channels from being modified so that you can't transform it directly? And if I wanted to use a parent constraint on a object and still be able to transform that object, would I have to use a proxy object? Basically applying the constraint on a proxy object, and doing the normal parenting of the object in question to the proxy object?
