How to rename a custom channel ?
roshanshilimkar3434
roshanshilimkar3434
I've got this rig in which all the custom channels are written in chinese. How do I change it to english ?
The attribute of the controller shows the name in chinese but when I right click and select that node it's written in english- https://drive.google.com/file/d/1iIEqIytSuFYB1NMznkHwv3pgcFzNG5Gr/view?usp=share_link
Kahylan
Hi!
There isn't a simple translation button for this. Since those are nice names given to the attributes. Atleast I'm assuming that because they contain non-Ascii characters and visibilty remained unchanged.
Now to display the long names you need to delete the nice names.
By hand you could do that by selecting an attribute, then in the channelbox menu using "Edit -> Edit attribute..." in the popup menu you then select your attributes one by one and delete whatever is in the "Nice name" textfield.
But doing this by hand would take a long time, especially since you have a whole rig with this problem.
So I wrote a python script for you that does this automatically:
import maya.cmds as mc
dag = mc.ls(dag = True)
for d in dag:
    attrs = mc.listAttr(d, ud = True) or []
    for a in attrs:
        mc.addAttr("{0}.{1}".format(d,a), e= True, nn= "")
When you run this script, it will at first look like nothing happend, but if you deselect and reselect the object you have selected, the attributenames should have changed.
I hope it helps!
roshanshilimkar3434
thank you very much, also the script has worked perfectly
