Maya Selection Filter 2018
abuyamman87
abuyamman87
Hy
is there anything like selection filter in maya as in 3ds max where we can select in the selection filter to only select  certain types of objects. i'e geometry or shapes or bones...
thanks is advance..
mspeer
Hi!
Please add more details how and where you want to select/filter, but in general, yes Maya can do this.
Just one example: Select -> All by Type -> ...
abuyamman87
Like there is a selection filter in 3ds max and there is a script too available, some one else wrote, in which you can bind shortcuts to like a geometry and shapes and splines and biped bone even cat bone too
mspeer
Hi!
selection mask:
https://help.autodesk.com/view/MAYAUL/2019/ENU/?guid=GUID-E3DBC099-2E93-47F3-B7FA-A219DB72B4A7
...and you can create hotkeys for almost every command used in Maya, also for the selection mask.
