Announcements
HELP! ERROR! Guide settings changed. Please re-perform skeleton embedding
I tried to save a quick rig work the way I usually save, but when I tried to skin it I got an error message
"Guide settings changed. Please re-perform skeleton embedding" PLEASE help!
I'm having the same issue. Did you find any solution to this?
I had the same issue... I'm VERY new at Maya so this is probably not the correct solution, but to fix it, I had to re-correct my guides and refrain from deleting the extra guide that appeared at the bottom of my model (I just moved it to a place where I already had a hip guide so it hopefully wouldn't interfere much.)
Anyone else manage to solve this issue in a slightly less guess-and-check way?
niroulayumi
Observer
Observer
Just figured out!!
This error comes when you delete the guides, so make sure you do not delete any guides while editing them.
Cheers!!
